Salta al contenuto principale
Annunciato il 16 ottobre 2014, identificabile dal numero di modello A1347 e EMC 2840.
Adding SSD Drive to PCIe model
Can anyone assist with what parts I would need to add an SSD to a Mac Mini 2014 that came with a PCIe 512 GB drive?
I'd like to make it a dual drive setup, but can't confirm what part is needed to do so. Any help would be greatly appreciated.
Questa è una buona domanda?
Punteggio 3
2 Commenti
me to i would like to recieve and so place a PCIE drive on my mac mini late 2014. can you send me the link for buying that item?
bst regards
da
@yannick17 - Review my answer for the details
da
Aggiungi un commento
2 Risposte
Soluzione Prescelta
If you already have the PCIe SSD then you're adding a SATA drive (either a HD or a SSD) You'll need the to follow this IFIXIT guide Sostituzione cavo disco rigido Mac mini Late 2014 and need this part & tool kit: Mac mini Dual Drive Kit. Be careful here! The size of the drive needs to physically fit (12 mm is about it).
If you have a SATA HD already then you'll want this: either the drive carrier with the SSD cable mounted Hard Drive Carrier w/ SSD Flex Cable - Apple P/N 076-00040 or the cable its self Cable, SSD Flex - Apple P/N 076-00018
Here's the IFIXIT guides:
Immagine All the hardware needed to a second hard drive to your 2011 or 2012 Mac mini.
Prodotto
$26.99
Immagine Mac mini Late 2014 Cavo PCle SSD
Guida
Sostituzione cavo SSD PCle Mac mini versione fine 2014
Difficoltà:
Moderato
15 - 20 minutes
Immagine Mac mini Late 2014 Cavo del disco rigido
Guida
Difficoltà:
Moderato
1 hour
Immagine Mac mini Late 2014 Drive Tray
Guida
Mac mini Late 2014 Drive Tray Replacement
Difficoltà:
Moderato
Punteggio 1
2 Commenti:
Dan, If I already have a fusion drive in there will I need any of these replacement parts, or can I just substitute the respective PCIe and 2.5 inch drives for the existing ones?
da
You'll need to make a full backup before doing anything.
First step is to break the Fusion Drive following this How to split up a Fusion Drive.
And yes, all of the needed hardware sans the replacement drive/s is present.
But before you jump what is your goals here?
da
Parti & Attrezzi Popolari
Acquista tutti
When adding a HDD to a PCIe SSD only 2014 mini, which HDD cable do you need? (1) the mini dual drive cable, or (2) the upper SATA cable?
Punteggio 0
Aggiungi la tua risposta
tomtcs sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 10
Tutti i Tempi: 1,555
