Salta al contenuto principale
Repair guides and support for the EOS 70D, a DSLR camera released by Canon in 2013. This camera can be identified by the model number DS126411.
replace the mode dial on canon 70d
how do I remove the mode dial on a Canon 70d ??
I have a replacement.
Questa è una buona domanda?
Punteggio 4
5 Commenti
Hi, did you manage to find out how to replace it? Having problems with mine, and have just ordered a replacement.
da
No, unfortunately I haven't replaced it. I found a posting on the net from a guy who enquired at Canon and was told that a strip-down costing a couple of hundred Dollars was neccessary.
Mine's is stuck on manual, so I've just been working with that.
da
Have done some research and have gotten in contact with a guy that repairs cameras. He told me I would have to strip off the casing before I can replace the dial (I think it's held on by a screw from the inside). Will be attempting the tear down when my replacement dial arrives. Will tell you how it goes.
da
Alexander,
I was quoted 248.00 for what might be a simple task. Where can I buy the mode dial? Have you actually accomplished this repair yet? If so, I'd like to know if maybe it was not so easy or worth the cost I was quoted.
Joanna
da
Alma,
Did you find a way to get that mode dial repaired?
Joanna
da
Aggiungi un commento
2 Risposte
Risposta Più Utile
this post is a year old, but for those who are still looking for an answer on how to replace the dial mode on the 70d, or any canon dslr for that matter, you might want to see this video https://youtu.be/rpE7Co3dfgo
Punteggio 1
1 Commento:
thank you!!!!
da
Parti e strumenti popolari
My camera is ded no power
Punteggio 0
Aggiungi la tua risposta
Alma Kohl sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 20
Tutti i Tempi: 3,426
