Salta al contenuto principale
Sesto modello di iPhone Apple, annunciato il 12 settembre 2012. La riparazione si fa in modo simile alle precedenti versioni di iPhone e richiede cacciaviti e strumenti di apertura. Disponibile con tecnologia GSM o CDMA, con 16, 32, o 64 GB, nero o bianco.
20 Domande Visualizza tutte
No Charging after Battery replacement. Old one has no function too.
Hello!
i put in a new battery into my iphone 5 (the old one was still working but wouldnt hold long), after replacement of the battery the phone worked fine. but after the first discharge it showed the battery logo with 3 small red stripes, it does recognize the charging cable but it won`t charge even after 12h+ of loading at the charger.
i thought maybe the new battery is dead so i installed the old working battery again and had the same problem like the new one. did i break something on the board or is there a fix for this?
i did battery repairs on iphones before and never had a problem, so i guess something is wrong here?
/are there any schematics so i could measure the current on the board?
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
2 Risposte
I've come across this problem in the past and spent many hours seeking solutions. Unfortunately, the best conclusion I could reach, is that something on the logic board was damaged when disconnecting the battery. This implies that you now a defective logic board and shouldn't expect to find any easier solution that replacing it.
Punteggio 0
1 Commento:
thats my thought too, but i`d like to verify this with a measurement.
/also it worked after the replacement. it stopped working after the first discharge.
da
TriStar switching ic switches between mains and battery (u2)
Punteggio 0
Aggiungi la tua risposta
einself sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 37
