problem with storage/SD card
I have an external SD card, i t won't allow me to add any of my apps. My tablet says storage space is running out, what is going on?
Questa è una buona domanda?
Hi,
When you go to move the apps, is there an option to do so or is it greyed out, (move to SD Card)?
If there is no option to do so or it is greyed out, it is because the developer of the app has not set the "permission" flag which enables it to be moved. This could either be by omission or design.
Also if the apps that you wish to move came pre-loaded with the tablet, they are part of the system and can only be moved if you root the tablet.
There is the option to move to SD card, but when I try to move it ,it reads no storage space. I even tried a new card and got the same results.
Hi,
Not sure if you have this setting but go to Settings > Storage and see if the SD card appears as a storage option and how much storage space is available.
Have you tried inserting the card into a card reader connected to a PC and see what is stored on it (if anything)?
If nothing is stored try formatting the card again and then re inserting it into the tablet.
Preparati per le riparazioni future
Either it's full of data, or hasn't been properly formatted.
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 5
Tutti i Tempi: 1,275
