How to access timing belts
How to remove the covert to the timing belts on a BBA 2865 breadmaker machine
Questa è una buona domanda?
It cost me a lot of nerves to get the white plastic clips off. They are also a pain to clip back on later.
So finally, here the top is off, ready for the white plug to be unplugged:
The earth cable still has to come off:
Now take care of the on/off switch:
The switch cables can stay plugged in. Mine were so hard in, I feared to break them off. Just be careful.
Important for later assembly: the three spacers.
Now the way is clear to replace the timing belts.
Fixed. View from underwards:
Good luck! ;-)
Great tutorial, helped me a lot on a BBA 2594 machine.
Thank You!
Preparati per le riparazioni future
Belt is at the bottom of the machine.
You need to:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 12
Ultimi 30 Giorni: 20
Tutti i Tempi: 841
