Salta al contenuto principale
The Nintendo DSi is the third iteration in the Nintendo DS line, and made its debut in Japan in late 2008.
How can I reset Parental Controls
I forgot the pin and the secret question. I tried calling them, but they said that the service was no longer available. WHAT DO I DO?
Questa è una buona domanda?
Punteggio 12
Aggiungi un commento
3 Risposte
Soluzione Prescelta
kdcao1 , 3 links below will take you through the process of resetting parental control if you have forgotten pin. and secret question. Good luck.
http://en-americas-support.nintendo.com/...
https://www.youtube.com/watch?v=_uvW3LZc...
http://xerohournix.blogspot.ca/2013/01/r...
Punteggio 19
9 Commenti:
Thanks, the last one helped the most.
da
The last link was the best one, helped me reset a second-hand DSi easily. Thank you so much!!
da
Same, the last one was the one! Thank u so much!
Edit: I used this for a dsi xl and it was quick and easy.
da
Tried only the last one & it worked thnk U
da
the last link worked on my DSI XL
da
Mostra altri 4 commenti
Parti e strumenti correlati
Acquista tutti
THIS TOTALLY WORKS :'D It saved my boyfriend and I so much time. It worked with a DSi that he bought from a third party seller. This really helped out! Would recommend to someone else
I followed the comments and went right to the third link! I was confused at first because you need to set the DSi's date to the current date
Punteggio 1
The last one helped thank you
Punteggio 0
Aggiungi la tua risposta
kdcao1 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 9
Ultimi 7 Giorni: 70
Ultimi 30 Giorni: 246
Tutti i Tempi: 48,925
