How can I reset Parental Controls
I forgot the pin and the secret question. I tried calling them, but they said that the service was no longer available. WHAT DO I DO?
Questa è una buona domanda?
kdcao1 , 3 links below will take you through the process of resetting parental control if you have forgotten pin. and secret question. Good luck.
http://en-americas-support.nintendo.com/...
Thanks, the last one helped the most.
The last link was the best one, helped me reset a second-hand DSi easily. Thank you so much!!
Same, the last one was the one! Thank u so much!
Edit: I used this for a dsi xl and it was quick and easy.
Tried only the last one & it worked thnk U
the last link worked on my DSI XL
Preparati per le riparazioni future
Acquista tuttiTHIS TOTALLY WORKS :'D It saved my boyfriend and I so much time. It worked with a DSi that he bought from a third party seller. This really helped out! Would recommend to someone else
I followed the comments and went right to the third link! I was confused at first because you need to set the DSi's date to the current date
Ultime 24 Ore: 4
Ultimi 7 Giorni: 55
Ultimi 30 Giorni: 235
Tutti i Tempi: 49,241
