Salta al contenuto principale
The Asus MeMO Pad 8 ME181C was released June 2014. It features an 8" screen, in a silver metallic case, with rear and front facing cameras.
Rear Camera will not work
When I click on the camera application, only the front facing camera will show a picture. When I click to switch it to the rear camera all I see is a black screen. Please help!!
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
I have had a similar issue with my personal tablet. My issue was solved by removing the case the tablet was in. The case did not have appropriate cut out for the rear camera. However If this is not your issue it sounds like your camera maybe bad. You should check out the trouble shooting page.
Asus MeMO Pad 8 Troubleshooting
If you still feel that the camera should be replaced here is a guide for replacing the rear camera.
Asus MeMO Pad 8 ME181C Rear Facing Camera Replacement
Punteggio 1
Aggiungi la tua risposta
Seth Gillett sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 4
Tutti i Tempi: 96
