Salta al contenuto principale
Linksys EA9200 is a tri-band router that is capable of providing up to 3.2 Gbps wireless speed. Has 1GHz CPU to quickly processor all network activities and request. Has 4 Gigabit ethernet connection ports and 2 USB ports (one is USB 3.0). Is compatiable with Linksys Smart WIFI Application for smart devices. Operates on high data traffic on 5GHz band and lower traffic on 2.4 GHz band.
Power switch not longer works
The power switch is not working, Can I replace it, or do I need to buy a new router?
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Hi Wendy,
I would not buy a new router you can simply replace the switch. For more information and steps on how to do this please check out this Power Switch replacement guide (this guide is not yet published). However, if you would like to replace the power switch you can simply disassemble the device with a few screws hidden underneath the stickers of the device. Then follow the iFixit How To Solder and Desolder Connections.
Immagine Soldering
Guida
Come saldare e dissaldare componenti elettrici
Difficoltà:
Difficile
Immagine Linksys EA9200 Power Switch
Guida
Linksys EA9200 Power Switch Replacement
Difficoltà:
Moderato
Punteggio 1
5 Commenti:
I will take a look at it. Thank you Henry
da
Henry Student , That link does not work.
da
I just checked it and it is working.
da
Keeps coming up Forbidden Access
You cannot view this guide. I just tried it again!
da
@lpfaff1
That is because we are students and we are building these guides for the EA9200. Wendy is part of our Team, so she has access. Part of the iFixit Requirements for team projects is we must produce 3-4 questions then answer them from within the team.
From Milestone 2 Overview:
http://edu.ifixit.com/milestone-2-overvi...
"Posted and answered three questions about your device
Confirmed that the three support questions automatically appeared on your device page under the "Support Questions" section"
Hope this clears it up for you!
Henry
da
Parti e strumenti correlati
Risposta Più Utile
Wendy, the switch is probably replaceable, the problem will be finding one. If you are sure it is the switch and not a faulty power supply, open the router and remove switch and see if there is a part # on it then do a google search with that info., or take the switch with you to a small electronics supply shop and have them try to match it up.
You may even be able to disassemble switch carefully and clean contacts and get it working. Another option would be to join/secure the switch wires together to make device powered on and use a switched controlled power bar as the on/off for router.Good luck.
Punteggio 3
Aggiungi la tua risposta
wendy sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 5
Tutti i Tempi: 394
