Salta al contenuto principale
The Nextbook NX008HD8G is an 8'' Android tablet released in September 2013.
Decoder Failed when open up cbs app
I downloaded cbs app to watch soap operas, and I get this message that decoder has failed. What does this mean? I deleted some of the apps to see if that was the problem, but to no avail.
Questa è una buona domanda?
Punteggio 2
1 Commento
I am having the same issue and I am not using a tablet but a high end dell computer
da
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Hi,
If you are talking about the CBS All Access app then I think that you will not be able to use it on your tablet.
According to the information in this link, the minimum system requirements for the app to work is Android Ver. 5.0 and higher. (Scroll down the page to see the Additional Information section).
https://play.google.com/store/apps/detai...
According to this link your tablet is running Android Ver. 4.01 (Jelly Bean). I have checked the Nextbook website and there are no firmware updates available from Nextbook for your model tablet.
http://nextbooktabletguide.com/nextbook-...
Punteggio 3
Parti & Attrezzi Popolari
This is a common device compatibility error where you need to use an upgraded android version to stream CBS. Check the device compatibility first and then go ahead with the '''cbs.com/roku''' activation process.
Punteggio 0
Aggiungi la tua risposta
Evelyn Lewis sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 1,261
