Salta al contenuto principale
Linksys EA9200 is a tri-band router that is capable of providing up to 3.2 Gbps wireless speed. Has 1GHz CPU to quickly processor all network activities and request. Has 4 Gigabit ethernet connection ports and 2 USB ports (one is USB 3.0). Is compatiable with Linksys Smart WIFI Application for smart devices. Operates on high data traffic on 5GHz band and lower traffic on 2.4 GHz band.
5 Domande Visualizza tutte
My USB port stopped working
My USB port has stopped working is there any way that I can fix it?
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Soluzione Prescelta
You may need to replace the USB port. This is fairly easy to do. It is soldered onto the circuit board with 6 contact pins. If you do not know how to solder iFixit has a great guide here. Come saldare e dissaldare componenti elettrici
Make sure the soldering iron reaches temperatures higher than 300 degrees Fahrenheit. Hope everything works well for you.
Punteggio 1
Aggiungi la tua risposta
Shane Davis sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 131
