How to replace a charging port?
My cable fits loosely in the port, It must be racked to make contact to charge.
Questa è una buona domanda?
@creat200 The 1 st link is a tear down of the MS3 and show how you can access the port and change. The second link is good info. on problems and solutions why the MS3 may have problems charging when plugged in. Check the attached links,instruction and guides, Good luck.
Link is for Surface PRO 3, not Surface 3. The teardown is a bit different, as is the charge port.
Parti & Attrezzi Popolari
Acquista tuttiUltime 24 Ore: 1
Ultimi 7 Giorni: 52
Ultimi 30 Giorni: 61
Tutti i Tempi: 20,545
1 Commento
Does anyone know the part name and number and where I could buy the charging port
I have Surface 3
da Lise L.
