Tacking down the home button bracket
I am in need of help tacking the home button down so as it will not come off, suggestion please and thank you.
Questa è una buona domanda?
Ottieni un rapido accesso alle guide, ai componenti e alle risposte per i tuoi dispositivi
Hi
In that case you have 2 solutions.
The first and easiest : you can emulate the Home button by software. For such purpose do as follow:
1) go into settings\General\Accessibility
2) In the INTERACTION Sub menu put AssistiveTouch ON
3) Then you will see a button appearing on your screen that will emulate the Home button. You can swipe it & put it at the place of your screen you desire.
The second ; it's hardest but better : you will have to remove the digitizer using a hot gun or better a Hot air soldering/dessoldering unit and then to put back/replace the button . Possibly you will have to buy a gasket before to replace the former one (very cheap).
Good luck
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 66
