Salta al contenuto principale
Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
Backlight on LCD not working
I saw several other people in this situation but no one actually answered the question I have.
Like many I got water damage... my question is if I replace the display assembly, will the backlight be replaced as well?
I have a black iPhone 3GS 8GB A1303.
You can see the display fine in sunlight but if I go into a room or low-light environment I can't see the display at all.
The display is working fine, just the backlight is out.
Any thoughts?
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
2 Risposte
Soluzione Prescelta
There are 3 places where damage may stop backlight - LCD, connector1 prongs on mainboard or the backlight coil itself which is on mainboard. Replacing LCD doesn't always cure the problem... There are a few good links on here about how to repair your coil ( James bond I think) . I would try cleaning the phone thoroughly with isopropyl alcohol first- you may have residue spoiling connections
Punteggio 1
2 Commenti:
The downside to that is I am currently stationed in Korea, so getting isopropyl alcohol isn't something feesible right now.
da
anything high content alcohol is all you need. 90% alcohol leaves 10% water, so the higher the % the better. you could just open the phone and try a soft brush to get rid of debris. many people refer to it as "rubbing alcohol" try that at the pharmacy/chemist...
da
Preparati per le riparazioni future
Acquista tutti
yes, it will be replaced, but it would be sad to pay that much if you could replace a couple LEDs or similar. If you do replace the displace assembly I would be more than happy to acquire your old one for the touch screen component if nothing else.
Punteggio 0
Aggiungi la tua risposta
Chris Ballentine sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 9,740
