Salta al contenuto principale
This PC is a Dell Inspiron 3000 Series laptop with an AMD processor and a non-touch display. It's model number is 3541.
20 Domande Visualizza tutte
I am Facing white vertical line on laptop screen
I am Facing white vertical line on laptop screen ..
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Hi,
Try connecting an external monitor to the laptop's HDMI port and see what the display is like.
If it displays OK then you either have a faulty video cable, a faulty video cable connection at either end (motherboard or screen) or a faulty LCD screen.
If it displays the same as the laptop's screen, then you either have a GPU problem (most probably CPU as they are integrated) or a motherboard problem.
If the problem appears to be not CPU/ motherboard related, here is a link to the service manual videos which may help you to gain access to your laptop so that you can locate the problem.
http://blog.parts-people.com/category/de...
Punteggio 4
Aggiungi la tua risposta
arslan Ahmad sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 6
Tutti i Tempi: 6,365
