Salta al contenuto principale
The Nikon Coolpix S33 Waterproof Digital Camera B00T85PKD0 is designed as an all purpose camera that is waterproof, shockproof, and freeze-proof.
17 Domande Visualizza tutte
My front cover glass broke
Can I replace the front cover?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
My camera broke as well...
I pulled out the silver ring that surrounded the original broken glass (it is easy to remove using a small pliers), cleaned all the broken glass pieces and ordered a flat glass watch crystal diameter 29mm Thick 1mm on aliexpress
Once it arrives i believe I can glue all the parts together again, almost like the original camera.
(search for "flat glass watch crystal diameter 29mm thick 1mm" on aliexpress, costs less than 2 dollars)
Punteggio 0
1 Commento:
Hi,
I'm curious to know if that worked and if the camera kept being waterproof. I thought about replacing the whole front cover but I don't find that part anywhere...
da
Aggiungi la tua risposta
alexander288 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 3
Tutti i Tempi: 175
