Salta al contenuto principale
Third generation of iPad with Wi-Fi, released on March 16, 2012. Model Number A1416. Repair requires heating and careful prying.
The LCD brightness is darker on one side after replacing?
i have just replaced the LCD on an ipad 3rd gen. I have completed the repair and now i have noticed that one side is darker in screen brightness to the other side. Why is this?
Questa è una buona domanda?
Punteggio 0
1 Commento
thanks Josh. i will have a look. i never use tools to disconnect cables. luckily my nails do the trick, but it maybe a screw too tight. Thanks for the info. :)
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
How much darker? Can't read it dark or just annoyingly dark?
If its just a bit darker, it could be as simple as a screw or something else is stuck under the LCD causing it to look funny. If its noticeably darker, then you blew one of the backlight filters. There are 2, one for each side of the screen. Its very common to blow those filters, especially if you used metal tools to disconnect the LCD or digitizer.
Punteggio 1
Aggiungi la tua risposta
Bev sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 89
