Salta al contenuto principale
This Power Mac G4 has Mirrored Drive Doors.
How do I remove the processor from a MDD computer?
I want to remove the processor and mother board from my computer so that I can install a new motherboard and processor but I cannot figure out how to release the processor from the board.
Any written instructions or photo help files on this topic would be greatly appreciated, thanks.
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
2 Risposte
Soluzione Prescelta
This guide is incomplete but will get you down to the CPUs.: How do I remove the processor from a MDD computer?
Please tell us the specific MDD you have (on a plate on the back of the machine.
Punteggio 2
2 Commenti:
Parti e strumenti correlati
Hello Laurie,
First you need to discharge yourself - touch a metal surface of the MDD with your hand and right after you've done that you can continue safely.
*Edit : Remove the Heatsink*
the yellow box indicates the connector underneath.
1 - in these two ellipses go your thumbs. apply a bit pressure.
2 - index and middle finger go under the board and pull up the board gently. you work against the pressure of your thumbs and the force of the connector. but I find this quite comfortable.
Regards Jan.
Punteggio 1
Aggiungi la tua risposta
Laurie sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 2,427
