mute button does not work
How to fix the mute button to work. Sound button OK
Questa è una buona domanda?
Follow guide for "Teardown"
and use at least 95%+ pure IPA (Isopropyl Alcohol.
I have been using my Harmony 700 for over 12 years and is still working very well with a clean up every few years or so as neened.
Yes the mute button gets a lot of use in our house.
Preparati per le riparazioni future
Mute button not working. Can it be fixed.
My logitech harmony 700 had the same problem for more and more buttons.
After opening it, I discovered house mite on the print under the metal discs. They prevented the electrical contact between the disc under the button and the copper of the print.
All mite were already dead and pressed flat.
I cleaned everything and closed the hole in the print for every button with some epoxy to prevent mite to creep in again.
Everything works fine now.
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 12
Tutti i Tempi: 2,476
