Salta al contenuto principale
The Logitech Harmony One is a universal remote by Logitech that was released in 2008. Logitech Harmony is a line of remote controls and home automation products produced by Logitech, an American-Swiss manufacturer of computer peripherals and software.
mute button does not work
How to fix the mute button to work. Sound button OK
Questa è una buona domanda?
Punteggio 4
Aggiungi un commento
3 Risposte
Risposta Più Utile
Follow guide for "Teardown"
Teardown
and use at least 95%+ pure IPA (Isopropyl Alcohol.
I have been using my Harmony 700 for over 12 years and is still working very well with a clean up every few years or so as neened.
Yes the mute button gets a lot of use in our house.
Punteggio 1
Preparati per le riparazioni future
Mute button not working. Can it be fixed.
Punteggio 0
My logitech harmony 700 had the same problem for more and more buttons.
After opening it, I discovered house mite on the print under the metal discs. They prevented the electrical contact between the disc under the button and the copper of the print.
All mite were already dead and pressed flat.
I cleaned everything and closed the hole in the print for every button with some epoxy to prevent mite to creep in again.
Everything works fine now.
Punteggio 0
Aggiungi la tua risposta
John Polich sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 13
Tutti i Tempi: 2,477
