Salta al contenuto principale
iPhone di quarta generazione. La riparazione è semplice, ma il vetro anteriore e l'LCD andranno sostituiti insieme. GSM / 8, 16, or 32 GB di memoria / Modello A1332 / Nero e Bianco.
Can it be fixed
I have an i phone4 i dropped it and the screen fell out and u can see the sliver part where the screen was and back its all smashed can it be fixed.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Risposta Più Utile
@dee30 sounds like you need a new display, It is a bit of a tedious repair but not that complicated. Use this guide for the repair. You can get the replacement either from ifixit or do an online search.
Immagine Replace a cracked glass screen or malfunctioning display compatible with a GSM model iPhone 4.
Prodotto
iPhone 4 (GSM/AT&T) Screen
$24.99
Punteggio 3
Parti e strumenti correlati
Acquista tutti
Yes it can be fixed. If you take it to a repair center they can replace the screen and the back casing too. As it's an iphone 4 the cost might not be as much due to the parts being cheaper, just depends what they charge for labour.
Punteggio -3
2 Commenti:
"take it to a repair center"? What do you think the purpose of this site is?
da
This site is called ifixit. What part of "I Fix It" do you not understand?
da
Aggiungi la tua risposta
Diana ok sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 56
