Salta al contenuto principale
Samsung WB2200F 60x zoom dual grip camera released in 2014.
How do I prevent my adapter from overheating?
I am trying to figure out what can be done to prevent the adapter from over heating.
Questa è una buona domanda?
Punteggio 1
1 Commento:
I was in this problem before
But i stooped use adapter
no i use SD card only
and everything right
da
Aggiungi un commento
1 Risposta
I had this sort of problem in the Philippines for a TV adapter. Due to the extreme heat of the country and the lack of airflow the ac adapter was overheating and the TV would turn off after a certain amount of time. So I had on of those Gel Cooling Pads for a laptop which I was not using. Mine looked like this.
http://www.amazon.com/Heat-Absorbing-Lap...
Anyway I wrapped it around the power adapter brick and rubber-banded it on.
OF course you might use something else but remember you are dealing with power so be careful.
Punteggio 0
Preparati per le riparazioni future
Aggiungi la tua risposta
Rachelle sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 7
Tutti i Tempi: 603
