Salta al contenuto principale
iPod Classic 6th Generation. Model A1238 / 80, 120, or 160 GB hard drive / black or silver metal front
DIfference Between Thick or Thin
How do I tell the difference between a thick and thin Ipod Classic 160
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Risposta Più Utile
@hughbabe you could use a kitchen scale and weigh your iPod. The "thick" is ~5.7ounce's/163g and the "thin" is ~4.9 ounce's/137g. Check your serial number on this site and see what it tells you. If it says iPod Classic its thick, if it says iPod Classic (late 2009) it's thin.
Punteggio 4
Thick: dual platter hard drive, thin: single platter hard drive.
http://www.everymac.com/systems/apple/ip...
The nice feature about the thick model is that there's more room for modifications like a 2000mah battery, if you remove the original hd and switch it out with a ssd.
http://forums.macrumors.com/threads/2-00...
Punteggio 2
Aggiungi la tua risposta
Michael sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 53
Tutti i Tempi: 5,521
