Salta al contenuto principale
Mid 2006 / Model Number: A1181 / black or white case / 1.83 or 2.0 GHz Intel Core Duo processor
Why cant I get into the apple hardware test
When I try to boot from os cd to use apple hardware test to determine if hard drive is the problem(vompletely reformatted hard drive using macdrive) and tried to do clean install of os will not install and will not go into AHT
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
1 Risposta
Risposta Più Utile
Try holding down the "D" key when booting from the original system installation disk. Also please tell us the problem you're having. Format the hard drive from Disk Utilities and using the "write zeros" option will map out any bad blocks.
Punteggio 1
1 Commento:
Aggiungi la tua risposta
Vinnie sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 1,294
