Salta al contenuto principale
Second generation of CDMA iPad 2 with 16, 32, or 64 GB and Dual Core A5 Processor. Model Number A1397. Repair is detailed and requires heat and prying.
Home button does not respond...
I re-installed digitizer screen and now home button does not respond.
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
You have damaged home flat, not rare damage in the process of digitizer replacement. Replace it and it will work. Good luck.
Punteggio 0
1 Commento:
That is cable that connects your Home button and motherboard.
Hint: iPad 2 CDMA Home Button Control Board Replacement
da
Aggiungi la tua risposta
Patrick Varley sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 7
Tutti i Tempi: 141
