Salta al contenuto principale
Third generation of iPad with Wi-Fi, released on March 16, 2012. Model Number A1416. Repair requires heating and careful prying.
154 Domande Visualizza tutte
Wifi button greyed out
I replaced the screen and after awhile the wifi button cannot be activated, should I replace the motherboard?
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
3 Risposte
Risposta Più Utile
No, you will probably just have to replace the wifi antennas, which is probably what got ripped when you opened the device.
Punteggio 2
3 Commenti:
I agree, everyone who has worked on iPads enjoyed one day or another a teared up wifi antenna ;)
da
Yup. Happens when you put the pick too far in on the right side.
da
What I'm afraid of is the wireless controller being messed up. That would be a board-level repair.
da
Sounds like you didnt reseat the wifi module properly, or as you were dismantling it you cracked part of the ribbon cable.Check , reseat, or replace the wifi module.
I assume you tried doing the cold reset and switching in amd out of airplane mode, this is usually a fix for airplay too when that “greys” out.Hope this helps.
Punteggio 1
Replace your wifi antenna iPad 3 Wi-Fi Wi-Fi Antenna Replacement
Punteggio 1
Aggiungi la tua risposta
Eric Wayne sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 212
