Salta al contenuto principale
The LN46A530 has a 46" display, combined with SRS TruSurround XT. The PC input allows this display to double as a 46" computer monitor
HDMI Problems and connecting
'''bold textMy HDMI cable attach from my notebook to the HDMI port on my Television is not working as it should be. When attach, all I am getting is the icons on the taskbar but none on the desktop and a different screensaver, I have tried unplug the television for 10 min, plug it back on, reconnect the hdmi cable, I usually use HDMI2, that did'nt work also the other HDMI port.
Questa è una buona domanda?
Punteggio -1
1 Commento:
Hi,
Can you try a different device on the HDMI inputs of your TV, e.g a dvd player or anything with a HDMI output? This is to isolate the problem to either the TV or your notebook. Also if you can try a different HDMI cable, again to eliminate possibilities.
da
Aggiungi un commento
1 Risposta
Did you use separate screen option? Or duplicate?
Is this the first time you used an Hdmi?
Punteggio 0
Parti e strumenti correlati
Aggiungi la tua risposta
Roderick Maloney sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 201
