Salta al contenuto principale
HD action camera with touchscreen LCD, released October 5, 2014.
How can I replace the touch screen?
I just bought my replacment rear screen yesterday i tried to replace it, but i couldn't remove the original. I could tear down almost totally (i removed even the battery box) but then i stuck. Thanks for any help.
Questa è una buona domanda?
Punteggio 4
6 Commenti
Thanks for your answer, but in the meantime i could replace it, and it solved my problem, now its like i have a new camera. It was tricky with that button cable but i made it work.
da
How hard was it to replace it? Did you use a tutorial? I can't see to find one online
da
Tom - can you please share how you replaced it? I can not figure out how to remove rear lcd without damaging anything and all tear down videos I've watched do not show this being removed.
da
I just replaced mine last night. it is glued to the black frame and has to be gently pried and re-glued. You may have to transfer the touch screen on/off toggle switch from the old screen assembly if the replacement you bought doesn't have one. Mine didnt so I had to remove and re-solder the button. Takes some advanced skills to do it but it was very quick and easier than I expected. I did crack my front lcd while removing it but it was already broken and needing to be replaced. It is also glued down.
da
Where did you buy the replacement touch screen?
da
Mostra 1 altro commento
Aggiungi un commento
1 Risposta
Risposta Più Utile
You might want to read my additional comments in my topic:
Saltwater drop / Rear LCD not working
Punteggio 1
Aggiungi la tua risposta
Tomi H sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 3,570
