Salta al contenuto principale
Introdotto il 19 settembre 2014, questo iPhone con schermo da 4,7" è la versione più piccola dell'iPhone 6 Plus. Identificato dai numeri modello A1549, A1586, and A1589.
Home key broken of ribbon
Hi everybody. I have an iphone 6 with broken home button. As I've read that missing original home button leads to error while update I'm interested in one thing. In my case only the button is broken of the little ribbon and ribbon is still in place with its little chip in the middle on ribbon. So my question is will this ribbon connected be enough not to take my phone to error state. This may be a stupid question since I'm no tehnicion but the ribbon has a chip in the middle of it and I'm wondering is that enough not to get stuck with error while doing an update.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
3 Risposte
Soluzione Prescelta
There is no chip on the ribbon, just a few passive components. In order for this to work, you need the chip inside the button.
Punteggio 2
2 Commenti:
I know you have a lot of answers, but ah.. You sure about that?
da
Yes. There is a chip on iPhone 5s, but not on iPhone 6 home button ribbon cable. Even if there is a separate chip, no one can guarantee it can work, the chips could be coded to each other.
da
Risposta Più Utile
i don't think so... If I were you, I'd take it to apple. See what they say. Pretty sure you won't get the error. Unless you put an aftermarket button on there
Punteggio 2
the same thing happened to my brother and he taped the hole with duct tape , wnet into settings and got up the home button help . hope it helps if not sorry but tried :)
Punteggio 0
2 Commenti:
Thats what I'm doing at the moment, enabled on screen home button via accessability. Thanks for Your help but I'm interasted what happens during softweare update, such as instaling new ios update and does the update go trought without errors?
da
Yes it worked fine for my bro
da
Aggiungi la tua risposta
BrZi sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 225
