Salta al contenuto principale
Repair and disassembly guides for GE Microwave ovens.
Loud noise when turntable is in use.
I have an over the range microwave. A rattling noise can be heard when the turntable is in use. When the turntable is turned off there is no noise. I have tried removing the glass plate and turntable roller not no avail. Should I remove the bottom of the microwave to gain access to the turntable mechanism ?
Questa è una buona domanda?
Punteggio 7
5 Commenti
This is a follow up to my previous comment. After receiving a second microwave, after 3 days it to started to make the same growling noise ?? So I decided to thoroughly clean the platter, base of microwave and roller assembly. NO MORE NOISE. GE should have a 'tip' noted on the plate when setting up new microwave. So now I have 2 NEW GE microwaves for the price of one !!!
da
I read all the advice, believe me there was plenty.
Tried all the solutions short of taking it apart and messing with the motor.
Finally I took the wheeled ring that holds the turntable tray completly and set it on my perfectly flat Corian counter. There's where I found the problem was with one wheel that was turning unevenly on it's teeny weeny axel.
E-bay solved the problem ~~ new ring for $11. It's been working fine ever since.
Occam's razor solution.
da
For me, the solution to the "chatter" was taking a single edge razor blade to the underside of the turntable glass plate. After scraping off the microscopic particles that even dish detergent left behind... VOILA ! ! ! The noisy chatter stopped.
da
There is dirt from the food that stick to the bottom of the microwave. Perhaps there is residue from the soup which is very thin layer on the surface. When the turntable turn around, the wheel is uneven and make the noise. To fix the issue. Use a wet foam wash away the residue or dirt. Make sure the surface is smooth. Then you can heat up your food again in the microwave with no noise at all. Easy fix the issue.
da
Does the sound came from Barbecue rotating motor which is on side ?
da
Aggiungi un commento
14 Risposte
Soluzione Prescelta
Hi,
Check for flat spots on the rollers on the roller ring. (It is what the turntable rests on.) If there are flat spots, unfortunately the ring has to be replaced as there are no individual rollers available
Punteggio 7
2 Commenti:
That was my problem as well, harden food particles on the roller track. Thanks!
da
I found the flat spots.
First I removed the turntable ring and tested on a countertop.
No joy ~~ the counter was slippery Corian. I tested it by turning on a cutting board that had a bit of grab to it. Voila' there was one tiny roller with a flat spot. I found the entire turntable ring, new, on E-Bay for around $12, better price than from GE.
Oh happy day, peace in the kitchen, no more thump thump.
Thank you!
da
Preparati per le riparazioni future
Acquista tutti
Had the same problem which was solved by cleaning the the entire track and wheels under the turntable. Amazing how much sound emanates from such a simple problem. Of course you should be very careful to have the parts placed correctly after they are removed for cleaning.
Punteggio 6
4 Commenti:
Remember to clean the underside of the glass turntable also. Apparently if food dries onto any of these three mentioned surfaces, rumbling can ensue. Mine's rumbling stopped!
da
Note: Thanks to Rick & Graham's combined suggestions, I was able to rule out the motor. Thank you ALL that posted/brainstormed!
da
And, amazingly, it worked for me, too. Who woulda thunk such a simple thing would work so well!
da
Fixed th e square wheels with a piece of 240 wet and dry, problem solved.
da
Read the problem folks...it going to be the motor ir plastic piece between the plate and motor or both
Punteggio 3
1 Commento:
Yes, the problem has not been addressed. We removed the turntable and the ring with the wheels and the noise persists. It is inside the the oven itself. The problem started outside of the warranty period. Losing faith in Panasonic.
da
Hello Richard - we have the same problem. Cleaning the wheels etc makes no difference. The problem is inside the oven itself, perhaps in the motor or thereabouts. We removed the turntable and the wheels and turned the microwave on and the noise still occurred. Quite loud and annoying. Only began after warranty ran out. Sorry I'm no help - can only commiserate.
Punteggio 3
2 Commenti:
The problem is probably the turntable motor. To prove it. pry off the plastic drive pinion, that the thing that turns the turntable, close the door and do a 10 or 20 second micro selection. If the noise continues it means the motor is faulty.
da
I tried this, and it stopped making the knocking noises; the wheels are good, and everything clean. What next??
This is a new Wellington microwave; I returned the last one as it was doing the same thing.
da
I had the same popping noise only when I put in the glass tray. I did clean it with dishwahser solution but still the same afterwards.
Only when I cleaned it with antistatic spray (same used for cleaning computer screens) did the popping sound stop.
Hope this helps, it saved me a trip to the technicians.
Punteggio 3
I have the same problem. I replaced the drive motor (~$50 part) and the noise is the same...or worse. Any suggestions?
Punteggio 2
7 Commenti:
I have the same problem with GE microwave. Loud rattling noise after 6 weeks of use. GE sent me an identical replacement. Same noise after 1st day. ANNOYING. I will look into track and turntable by interchanging parts, POOR QUALITY ASSURANCE BY GE.
da
I have the same problem. My microwave is a Sears Kenmore. This is not unique to a certain brand. I have actually had mine for 7 years. This problem just started last week. It makes bumping noised and has a loud screech when it turns.
da
my 15 year old GE was screeching until i put a drop of 3 in one oil down the shaft of the motor in the floor of the microwave (just pull the plastic piece straight up to access it) bob
da
Solved!!
Mine sounded like someone rhythmically knocking their knuckle on a table top about 2 knocks per second.
My microwave was clean, I thought, (it looks like it just came out of the box).
I first removed the track and rolled it on a super smooth surface. No flat spots.
I then took the tips of my fingers and lightly ran them around the path the rollers would take. Voila'!
An invisible bumpiness I was barely able to feel.
Gave her a good wipe all around and she's running like new!
Thanks for saving me a bundle! You rock!
da
Perfectly !!!!! The problem is solved when I cleared the ring and base of the plate.
Thanks for the ready solution...
da
Mostra altri 2 commenti
Same problem with thumping noise in GE over the range Microwave. Visual inspection revealed nothing but running my finger around track that ring rides on located a small bump which blended perfectly with the bottom track. Cleaned the track, wheels and underside of glass turntable. Voila’ problem solved.
Punteggio 2
This may not solve your problem, but everyone has cooking spray (any type of oil will work to diagnose where the problems is) and you do not need to tear into your machine and no repairman involved. My problem was the plastic ring with wheels that goes under the turntable. The little wheels rotate on a little axle, and applying a drop of hi temp cooking spray to each wheel/axle did the trick. Now, it’s absolutely SILENT.
Punteggio 1
I had the same problem except there was no noise if I took the glass tray out. It only happened when the tray was on the turntable. After reading these comments, I checked the wheels of the turntable. No flat spots or problems there. Finally, I spotted a tiny crumb on the bottom surface of the microwave, right in the ridge where the wheels roll. It was small, but quite hard and white in color…hard to see on the white surface. I removed it and no more rattling!! So wipe out the bottom of your microwave if all else fails!
Punteggio 1
I sprayed silicone oil down the opening of spinning table plastic gripper on my Samsung microwave. Stopped the noisy vibration.
Punteggio 1
Glad I found this site. I was concerned that a motor replacement would be needed. But I sprayed silicon lubricant into the hole and canola oil onto the wheels and, so far, all is quite. Thanks to all for the suggestions, Pete
Punteggio 1
2 Commenti:
Re spraying silicone lubricant into the "hole", do you mean the small round "hole" under the small round plastic piece (with grooves) that the turntable rests on top of? If not, PLEASE describe the hole that you sprayed the silicone lubricant into. Thank you.
da
You just saved me big money My Toshiba started to make turntable noise yesterday. Like the glass was off the rollers. Nope, Flat spots Nope. Food Nope Nope. Didn't know the thing covering the middle hole would come off, YES it does.. THANK YOU ALL. Dropped Canola in the hole and POOF it worked. Toshiba is one year old. March 2025 Lori
da
We use our microwave to make bacon for breakfast, the microwaveable cooker is so large that our microwave’s turntable cannot rotate, so after a while our microwave starting making bumping sounds when we used it.
I found your page here while searching for possible reasons online!
I did what people here had suggested, I checked for flat on spot/s roller wheel/s, found none, I wiped all the roller wheels clean, and also cleaned the track that the rollers wheel travel on the microwave.
Thrilled to report, no more bumping sounds, our West Bend Microwave is working like a charm!
Punteggio 0
I see that this is a question from 2015. Back to the future in 2022, I had the same problem, a knocking sound as the turntable rotated. With the turntable removed, no noise! I cleaned the roller track as per previous answers and the noise disappeared. Good question, correct answers! Many thanks.
Punteggio 0
This is a very helpful thread! Apparently this type of noise -- although it sounds like something terrible has happened -- is often quick, easy (and free) for a householder to fix using no tools.
In my case the glass turntable and the support ring with the three little wheels were fine, and the sound continued when I removed them.
But the coupler - that approximately 2"plastic part with three legs that engage the bottom of the glass turntable - had been pushed down and was tight to the metal floor of the oven. I pulled it up an eighth of an inch or so and the sound was gone.
Interestingly, when I replaced the glass turntable on its support ring, and pressed firmly downward, the coupler did not move back down. It is apparently designed to ride above the metal floor of the microwave with a comfortable clearance. I have no idea how we managed to drive it down against the metal.
Punteggio 0
Aggiungi la tua risposta
Richard Peck sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 15
Ultimi 7 Giorni: 103
Ultimi 30 Giorni: 461
Tutti i Tempi: 83,346
