Salta al contenuto principale
The Canon EOS 60D is a 18 MP DSLR (digital single-lens reflex) camera with an articulating LCD screen. The camera was released August 2010 and is identified by the EOS 60D printed on the front of the camera.
HELP! Error Code 70
I keep receiving an error 70 code when I try taking photos. I turned the camera off and back on, but after several photos the error showed up again. Does anyone know how to fix this?
Questa è una buona domanda?
Punteggio 7
1 Commento
I get the Err 70 code to and can't do any thing else at all and after about a minute the camera shuts off. any help would be nice thanks
da
Aggiungi un commento
6 Risposte
Risposta Più Utile
If the automatic sensor cleaning is enabled, it causes an error 70.
That is, the automation solution is put off.
But I do not know what is the reason behind it.
Punteggio 2
1 Commento:
thanks seems to have solved my problem "THANK YOU"
da
Preparati per le riparazioni future
This is a memory card read/write error. First try to format the memory card. If the error continues after formatting (or the camera won't let you format the card), try a different memory card. If the error continues with a new card then you probably have an issue with the camera itself. Contact Canon for service. I hope this helps.
Punteggio 1
Hey everyone.
My error 70 let me shoot in auto, CA, C1, C2 and C3 on my Canon 7d mark I.
After realizing I need to somehow update my firmware and that you cant update firmware unless in settings P, Tv, Av, M or B Ifound that if I set the camera to video I could use P and update the firmware I had loaded onto a formatted memory card!
Hope this helps someone else!
Punteggio 1
I had this problem toobut the solution is to deactivate the autocleaning. The it shoots nornaly
Punteggio 0
4 Commenti:
I have this problem too and have format the card but still writing error 70
da
Please help me
da
Have AUTOCLEANING set to OFF
da
Please check image Sensor
da
Hi, i fixed this error on my EOS 600D with Tornado EOS program. Do factory reset and problem solved.
Punteggio 0
1 Commento:
what do you mean Tornado EOS program?
da
I faced the same issue on my 60D.
Tornado EOS programn is really awesome! I used the free version to upgrade the firmware and problem solved!
Punteggio 0
Aggiungi la tua risposta
Tyler Vaal sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 54
Tutti i Tempi: 25,894
