Salta al contenuto principale
Repair information for the Huawei Ascend G7 smartphone. Released in 2014. Model numbers: G7-L01, G7-L03, G7-L11, G7-UL20.
My device cannot turn back on
Hi.. i use Huawei Ascend G7 about 6 month. I want turn on my device after suddenly off it cannot turn on anymore. Can you help me?
Questa è una buona domanda?
Punteggio 5
1 Commento
Same problem of my phone
da
Aggiungi un commento
5 Risposte
Risposta Più Utile
estimado amigo lo primero que puede ocurrir es que la bateria como comunmente decimos los tecnicos esta muerta o sea sin carga necesitaras acudir a un sat y que te reanimen la bateria. la bateria pierde toda su carga si no se utiliza durante un tiempo.
espero haberte ayudado
Punteggio 1
If you try and charge it and there is a red light flashing, it means that the battery is over-discharged, you should probably go to the phone shop and they can help.
Punteggio 1
hi joselber mejo
kindly translate to English plz
Punteggio 0
sfdgkjvbnwsv vfweijsfvnw svusfvhsfvkmdfb afoiwefngcv wo sdfkosgsfc nrgoiwretjhdhb sdlkfhSDF neorfghferg sfdpgjszfdh ndlkfgjhwarg bzdb 9sgjdflbm,rgjkn ghkl;gnkgh7gn5fghemlgknsdigndgbndgbv fxhnhnfbn
translated :)
Punteggio 0
I also am facing the same problem :(
Can anyone help :(
Punteggio 0
Aggiungi la tua risposta
jienotti sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 4
Tutti i Tempi: 1,134
