Salta al contenuto principale
A touchscreen smartphone made by LG released in September 2013 with the model number VS980.
Navigation bar buttons not working in landscape
Questa è una buona domanda?
Punteggio 1
1 Commento
Mine aren't rotating to landscape and I need it to
da
Aggiungi un commento
3 Risposte
Risposta Più Utile
Is it just those buttons in landscape, or is touch in general not working on that column or row on the screen?
If the touch in general is not working, it very likely needs a new digitizer/LCD assembly. Technically you'd just need the digitizer, but it's adhered to the LCD and it takes quite a bit of practice to do glass only repairs.
Punteggio 1
1 Commento:
The buttons work fine in portrait. The generic screen position of the nav bar is the same i.e. bottom of the screen in portrait and extreme right when landscape. So touch seems to work fine...
da
If restarting or resetting your G2 to factory defaults doesn't work, the digitizer is failing. Most probably, it just needs a hard restart. If some cases, you can wipe out and reinstall the OS. It should be fine then.
Punteggio 0
2 Commenti:
Ill give hard reset a try later today
da
Hard restart didint help. Neither did reinstalling a new OS.
da
How can I change navigation bar theme to lollipop 6.0 in LG VERIZON VS980 4G LTE
Punteggio 0
Aggiungi la tua risposta
Sushil sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 10
Tutti i Tempi: 910
