Salta al contenuto principale
Model A1297 Unibody: Early 2009, Mid 2009, Mid 2010, Early 2011 & Late 2011
Is it possible to use a SSD instead of my optical drive?
MacBook Pro unibody early 2009
The question is. When I remove the optical drive. Will a SSD 2,5" fits on that place? Can I use a solit state disk on the place from my optical drive.
I want to use an extra SSD for OSX and stay using my harddisk for data. I never use CD's/DVD anymore so, that would be a great solution.
Thanks in advance,
Alex
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
4 Risposte
Soluzione Prescelta
Your MacBook Pro should be one of these two models:
  • MacBook Pro 17-inch 2.66GHz (MB604LL/A) Intel Core 2 Duo
  • MacBook Pro 17-inch 2.93GHz (CTO) Intel Core 2 Duo
What you need is called an Optical Bay SATA Hard Drive Enclosure
http://www.ifixit.com/search?x=0&y=0&tex...
I can't tell if you need the 9.5 mm or the 12.7 mm till you confirm your model. Even if I can't, iFixit parts will know. Just ask them here:http://www.ifixit.com/Info/contact
Punteggio 4
2 Commenti:
Preparati per le riparazioni future
Acquista tutti
Hi Mayer, my model is a begin 2009 MacbookPro 15" I will ask it to ifixit as you told me. Good to know that this is possible! Thanks for help!
Punteggio 0
I have swap my optical drive with a SSD using the enclosure adapter on my Macbook Pro. Now this new SSd sometimes disappears. I have to reboot my macbook pro, and sometimes that also does not work the first time. Any clues ? thanks !!
Punteggio 0
Oh yes, my model is Macbook Pro 5,2
Punteggio 0
Aggiungi la tua risposta
Alexander van der Linden sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 3,924
