Salta al contenuto principale
Third generation of iPad with Wi-Fi, released on March 16, 2012. Model Number A1416. Repair requires heating and careful prying.
Crashed and threw Error code -22
My friend gave me his Ipad 3 after he said it crashed and then while he was trying to restore the ipad it threw the error code -22.
I took the ipad home and was able to connect it to itunes and try a restore, it said unable to restore and it gave me the option to restore again, which I did. Now the ipad is not holding a charge and can't charge or even be "seen" by my cpu.
What does error -22 mean, and how can I fix it?
I know how to tear apart an Ipad and put back together correctly.
Thanks!
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
2 Risposte
Follow this link for information and way to restore the issue:
https://discussions.apple.com/thread/481...
Punteggio 0
1 Commento:
I don't know anything about software, and also the iPad can no longer be "seen" by my cpu.
da
Parti e strumenti correlati
Acquista tutti
Hey there,
Error code 22 is a Device Manager error that occurs when a device is causing a problem. This error code indicates that the device is disabled in Device Manager. Error code 22 can be fixed by enabling the device in decvice manager.
Punteggio 0
1 Commento:
How do I go to device manager if my device will no longer power on?
I don't understand how error 22 makes my device lose the ability to hold a charge and power up.
da
Aggiungi la tua risposta
Andrew sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 3,007
