Salta al contenuto principale
Compact video camera recorder/tape recorder Released 1989, Model No. CCD-TR5 Serial No. 257152
Why is the viewfinder show blank white
I can not see through it
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
4 Risposte
Soluzione Prescelta
Try to put in to camera mode, on the top there is a black with green switch turn or swap it to the left. (Sorry for My bad English I'M From holland)
Punteggio 2
This didnt help for me, its still white. In play aswell as camera mode. Its flickering and when FF or RW is pressed it also flickers how i would expect it to but still only white. When i first powered it up i saw like 1sec Snippets of image then white again, now only white and Flickering
Punteggio 1
I have the same.. Any answers?
Punteggio 0
I have the same issue. I suspect it’s a power/regulation issue or a video board issue with the Surface mount electrolitic capacitors that dry out or leak over time. I ordered some of these capacitors and I’m going to replace some of them and see if it helps to restore the picture.
Punteggio 0
2 Commenti:
Did it work?
da
It revived the viewfinder but I still had a garbled picture. There still is something wrong on the video board in the camera.
da
Aggiungi la tua risposta
paxton sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 29
Tutti i Tempi: 3,456
