Salta al contenuto principale
L'Apple iPhone 5s è stato presentato il 10 settembre 2013. La riparazione di questo dispositivo è simile a quella dei modelli precedenti e richiede cacciaviti e strumenti di apertura. Disponibile nelle versioni GSM o CDMA con capacità di 16 , 32 o 64 GB nei colori Argento, Oro e Grigio Siderale.
Logic Board replacement part
Can I purchase a motherboard, unlocked /(from any network or icloud) for use of this device (iphone 5s 16gb) in UK from ifixit ?
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Risposta Più Utile
iFixit does sell logic boards. Find them here: [prodotto collegato mancante o disabilitato: IF124-028]
They are, however, carrier locked -- so would not be useful in the UK unless you paid the carrier to unlock them here. If the phone that the logic board was removed from is not under contract, the carriers are required to unlock the board by law. You'd still need to boot the phone to get the serial number in order to ask the carrier to unlock it.
Be careful though -- International phones may require different attennaes than you will find on a stock USA GSM logic board. You may not get proper reception.
Punteggio 1
1 Commento:
I have noticed that many verizon LTE phones , which would include the iPhone 5S do come unlocked for use on other carriers by default. but since ifixit says it is locked to Verizon ,idk I guess not..... also an ATT motherboard can be unlocked for use with other carriers. the sprint motherboard can only be unlocked for use outside the US, and it is more expensive to unlock that an ATT motherboard. Buying the ATT motherbaord and unlocking it should work.
interesting to see that ifixit sells iphone motherbaords.
da
Aggiungi la tua risposta
gerryknoud sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 1,014
