replacing the HDD with an SSD
Is it possible to replace the HDD with an SSD on my HP G71?
Questa è una buona domanda?
Yes you can.
You'll get some performance improvement after SSD replacement as the systems CPU & memory will limit you. You will gain more run time using the laptop in battery mode, than running with a HDD.
Modern SSD's come with auto sensing SATA III (6.0 Gb/s) interfaces. Your systems chip set only supports SATA I (1.5 Gb/s). The SSD will sense this and run at SATA I (1.5 Gb/s) speed.
Preparati per le riparazioni future
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 2
Tutti i Tempi: 791
