Salta al contenuto principale
The Kenmore Elite HE3 is a washing machine by Kenmore. It is identical to the Whirlpool Duet.
My washer has a. oL code
I just bought my washer from a friend but when I wash it gets all the way to spins and a oL code cocomesp and thatsbit and all the clothes are soaking wet. I've tried all kinds of different things. I took all the clothes out to see if that helps and it does the same can anyone help me please.
Questa è una buona domanda?
Punteggio 2
Aggiungi un commento
1 Risposta
Soluzione Prescelta
shortiemomma2, empty the washer and spin the basket to check if it rotates freely. If it does not, then something may be caught between the spin basket and the outer tub which could give you an OL code. Also check for any obstruction underneath the washer by the motor that could be interfering with the motor. If you do not find any problems with the spin basket, then there could be a problem with the tub bearing, or worst with the control board or the motor.
Punteggio 1
Preparati per le riparazioni future
Aggiungi la tua risposta
shortiemomma2 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 4
Tutti i Tempi: 4,875
