Salta al contenuto principale
The PowerBook G4 Titanium Series was initially announced at Steve Jobs' keynote at MacWorld Expo in January 2001.
Will LCD from a Mercury work in an Onyx?
Will the LCD assembly from a 400 MHz Titanium Mercury work in a 550 MHz Titanium Onyx?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Soluzione Prescelta
I finally got a used Mercury laptop for cheap. It had a bad logic board. I can confirm that the logic boards and keyboards on the Onyx and Mercury are not interchangeable. The Onyx uses PC 133 RAM so it can be used in a Mercury (PC100) but not vice versa. However, I was able to successfully transplant the Mercury's LCD assembly into the Onyx and now I have video. The optical drives, modems and hard disks are also interchangeable.
Punteggio 1
Risposta Più Utile
Since they have different part numbers I would think they are not acceptable swaps, but wait for Ben to be sure. Mercury 661-2539 Onyx 661-2568 Ralph
Punteggio 1
1 Commento:
If you have the other display compare the connectors and cable lenghts. Ralph
da
Aggiungi la tua risposta
Bernie sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 628
