What do I do if the battery explodes?
After use, the device battery has puffed up like a bag of popcorn, and I am unsure if it can be repaired or will need to be replaced.
Questa è una buona domanda?
Ottieni un rapido accesso alle guide, ai componenti e alle risposte per i tuoi dispositivi
Exploding battery is a common problem associated with the device. If you notice bulging in the back of the device indicating the battery has expanded, or the battery has exploded entirely it is necessary to replace the battery for continued use. See Battery Replacement Guide for replacement instructions.
If its just the battery it can be replace with the mother board. My friend took out the battery an replaced it with a new mother board and battery it works just fine now
Teishka Candelario why would you suggest to replace the motherboard? The device definitely needs a new battery but not sure why you think it would need a motherboard.
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 7
Tutti i Tempi: 1,509
1 Commento
Take the battery out
da JaydenGill
