Salta al contenuto principale
The Vivitar Vivicam T027 is a digital camera with a resolution of 12 megapixels and digital zoom. The camera has 2.7” screen, the ability to produce large prints, and tools such as anti-shake and red eye reduction.
Domanda Chiusa
Why is the flash not working?
The flash does not go off when the button is pressed.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
There are several different reasons this could be happening. First, reset your camera by removing the SD card and batteries and then try again. If you still have a problem, clean the lens with a q-tip of any dust or other obstructions that may be jamming the lens. Lastly, gently tap the lens to see if it unjams. If none of these options work, the lens itself might need to be replaced.
Punteggio 0
Preparati per le riparazioni future
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 194
