Salta al contenuto principale
Queste guide contengono informazioni su utensili specifici per compiti come riparazione, costruzione o taglio. Puoi imparare come utilizzare gli utensili funzionanti per riparare quelli rotti.
Domanda Chiusa
Some one using TI EV2300 to program/hack a Battery back
TI EV2300 is a tool to program BQ series battery gauge.
I'm considering to get my A1185 out of "Permanent Failure" using EV2300.
Some one ever tried that or have some info/suggestion?
Thanks!
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
did you check the lipo cells first? are the fuses ok? - if a battery fails - it's most likely the problem of the cells and not the pcb inside the battery
so checking the voltage of every single cell and their fuses would be my first step - but that involves disassembling the battery (be careful and don't bent the cells)
Punteggio 0
1 Commento:
'cause i'll replace the cells and the g**d*** "self destructive" fuse. and i know what i'm doing.
just need some tool to reset BQ20Z80 status.
i don't know if this can be done by just programming SMBus...
da
Parti e strumenti correlati
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 2,796
