Salta al contenuto principale
Guide per lo smontaggio e la riparazione dei computer Macintosh di Apple.
Domanda Chiusa
Converting VGA cable to thunderbolt
I was wondering if anyone has attempted to connect a VGA cable to thunderbolt cable and if you know if its easy. I have thunderbolt cable that is damaged on one end (chair rolled over it and now it doesn't work)and i want to hard wire into a VGA cable (got a bunch of these so don't care if a damage a few in process) so I can still use this expensive thunderbolt cable to connect to an old VGA monitor.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
I do not believe a direct wire would work - the signal would have to be converted with some sort of circuit.
If this answer is acceptable please remember to return and mark it accepted.
Punteggio 1
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 120
