Salta al contenuto principale
Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
Why is my screen dim?
Hello
I recently repaired an iPhone 3GS. When I had connected the last of the ribbon cables, i turned the phone on. It worked, but it was extremely dim (practically black). I managed to make it to settings and adjust the brightness, but neither sliding it all the way up or all the way down had any effect. Then, when i disconnected the display and tried to connect it again, nothing was displayed at all! What could this be?
I was replacing both the LCD and the glass.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
4 Risposte
Soluzione Prescelta
It sounds to me like a backlight issue. What were you originally repairing on it?
First, double-check the connectors.
Then, I would replace the Display first. If this does not fix the problem, signs point to the logic board, unfortunately.
Punteggio 3
Preparati per le riparazioni future
Acquista tutti
it could be a bad lcd chip on the logic board. it happens a lot with liquid damaged phones. if a new lcd does not work then i would believe the chip would need to be replaced. no guarantee. it's extremely difficult to solder something that small, but we're champs at it here.
Punteggio 0
I think you can check the 6R8 coil,most of the backlight issue was caused by this item
Punteggio 0
Same issue I got.Only difference is My LCD is still working with only exception of very dim screen. Any fix to this issue? Please let us know if you got it fixed.
Punteggio 0
Aggiungi la tua risposta
sportsrocks213 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 6,009
