Salta al contenuto principale
Il Nerf N-Strike Recon CS-6 del 2008 è un blaster a dardi manuale, personalizzabile e alimentato a clip, venduto da Hasbro.
How do I remove the magazine?
Instructions for removing the magazine from the gun.
Questa è una buona domanda?
Punteggio 6
Aggiungi un commento
10 Risposte
Risposta più utile
To remove the magazine there are two buttons located on each side of the gun. Use both hands to pull back both buttons at the same time, and then the magazine should simply fall out.
Punteggio 5
2 Commenti:
yeah bro its easy
da
Which side are the buttons on
da
Yellow model: Pull the grey slide mechanism back. Open the black hatch. Push down on the magazine while sliding the two orange unlock buttons.
Punteggio 4
2 Commenti:
works for recon mkII as well
da
This is the answer I was looking for! Thank you! Just pulling the release buttons did not work
da
Pull the slide back and pull the orange release next to the magazine
Punteggio 2
How do I remove the magazine if the slider is broken and cannot slide back?
Punteggio 1
3 Commenti:
Try firing the gun
da
smash it on your sofa like a madman
da
If the cover of the sliding mechanism comes off, use a long thin screwdriver and push it through the holes in the long slits, and then pull that back. If the slide wont pull back, try firing the gun and then pulling back. If that doesn't work, open up the blaster (please record what you're doing it as you're doing it in case you cant easily re assemble it) and try and see if its jammed.
da
I have placed my darts of my recon cs-6 accidentally but i cannot open it because it is too hard i cant use the opener
Punteggio 1
1 Commento:
:o its jammmedso hard?
da
https://www.youtube.com/watch?v=pU5waRnk... Watch this and see
Punteggio 0
The orange button near the trigger will release the magazine
Punteggio 0
my slider is broken and i cant release the magazine
Punteggio 0
1 Commento:
me either it is soooo jammed that i am poop
da
You have to pull the reloading trigger on the top and push the button on one. the pusher)
Then take out the mag.
Punteggio 0
My magazine won't come out of the
Punteggio 0
Aggiungi la tua risposta
Asad Qureshi sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 6
Ultimi 30 giorni: 75
Tutti i Tempi: 36,252
