How do I remove the magazine?
Instructions for removing the magazine from the gun.
Questa è una buona domanda?
To remove the magazine there are two buttons located on each side of the gun. Use both hands to pull back both buttons at the same time, and then the magazine should simply fall out.
yeah bro its easy
Which side are the buttons on
Yellow model: Pull the grey slide mechanism back. Open the black hatch. Push down on the magazine while sliding the two orange unlock buttons.
works for recon mkII as well
This is the answer I was looking for! Thank you! Just pulling the release buttons did not work
Pull the slide back and pull the orange release next to the magazine
How do I remove the magazine if the slider is broken and cannot slide back?
Try firing the gun
smash it on your sofa like a madman
If the cover of the sliding mechanism comes off, use a long thin screwdriver and push it through the holes in the long slits, and then pull that back. If the slide wont pull back, try firing the gun and then pulling back. If that doesn't work, open up the blaster (please record what you're doing it as you're doing it in case you cant easily re assemble it) and try and see if its jammed.
I have placed my darts of my recon cs-6 accidentally but i cannot open it because it is too hard i cant use the opener
:o its jammmedso hard?
https://www.youtube.com/watch?v=pU5waRnk... Watch this and see
https://www.youtube.com/watch?v=pU5waRnk... Watch mah vid brah
The orange button near the trigger will release the magazine
my slider is broken and i cant release the magazine
me either it is soooo jammed that i am poop
You have to pull the reloading trigger on the top and push the button on one. the pusher)
Then take out the mag.
Ultime 24 Ore: 1
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 35
Tutti i Tempi: 34,963
