Salta al contenuto principale
The Nerf Dart Tag Furyfire is a toy gun which fires rubber Nerf darts. It is equipped with a rotating chamber and pump-action barrel for rapid fire.
2 Domande Visualizza tutte
Why are my darts not firing?
My Nerf Dart Tag Furyfire will not fire. What could be causing this issue?
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
2 Risposte
If your gun is not firing, ensure that you have darts loaded in the chamber and that they are loaded properly. The barrel may be clogged, so check the barrel for any debris. The final problem may be that the large spring in the gun needs replacement. If the previous issues have been resolved with no success, open up the Nerf gun. You will see a large spring towards the top of the gun. Remove the spring for replacement. See our troubleshooting guide for more details.
Punteggio 0
i can't remove the shotgun barrel at all even with tools
Punteggio 0
Aggiungi la tua risposta
Bradley sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 12
Tutti i Tempi: 1,605
