Salta al contenuto principale
iPhone di quarta generazione. La riparazione è semplice, ma il vetro anteriore e l'LCD andranno sostituiti insieme. GSM / 8, 16, or 32 GB di memoria / Modello A1332 / Nero e Bianco.
Sensitive screen after LCD screen replaced?
When making calls the phone will go on speaker or mute after the LCD screen was replace
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
2 Risposte
This just sounds like it might jut be a faulty screen there's no way to stop it being to sensitive
Punteggio 0
Preparati per le riparazioni future
Acquista tutti
This actually sounds like the devices proximity sensor isn't functioning properly.
If the screen were "too sensitive" then the issue would also be present when the device is away from your face, such as the reported ghost fingers issue.
Chances are the device requires a UV screen over the proximity sensor. Some devices, such as the white iPhone 4, must alway have this or the result will be exactly as you've stated.
If you need parts for your fix, I'm sure you can get them here at www.ifixit.com
Punteggio 0
Aggiungi la tua risposta
Brenda sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 286
