Salta al contenuto principale
Sesto modello di iPhone Apple, annunciato il 12 settembre 2012. La riparazione si fa in modo simile alle precedenti versioni di iPhone e richiede cacciaviti e strumenti di apertura. Disponibile con tecnologia GSM o CDMA, con 16, 32, o 64 GB, nero o bianco.
Digitizer LCD problems after repair
I replaced the digitizer LCD assembly and there are 2 thin lines running down the length of the phone about 1/4 inch apart. (on the right side of the phone running from top to bottom) In between the lines, the touchscreen doesn't work. Is this a bad part or a connection problem?
Thanks,
Karen
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
3 Risposte
Soluzione Prescelta
I see this all the time. Try re-seating the connectors. Sometimes they seem to be all the way in but are not. That fixes it most of the time. If it doesn't then yes, you have a defective part.
Punteggio 0
1 Commento:
Thanks, will do!
da
Preparati per le riparazioni future
Acquista tutti
also make sure your wearing esd gloves or wrist strap, ive killed a couple of display assemblies from shocking them but none since ive gone the glove method :)
Punteggio 0
As PDM says, reconnect the connectors, and also disconnect the battery to do e power cycle. Also check for dust and dirt in the connectors on the motherboard :-)
Punteggio 0
Aggiungi la tua risposta
Karen sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 128
